questions
Old Jun 6, 2004 | 03:35 PM
87carbed's Avatar
87carbed
Question questions
ive got a 1987 f-250 XLT lariat extended cab, with a carbed 7.5 liter 460, that i had a few question about. i am trying to get as much information as possible about it.
here is my VIN number: 1FTHX26L9HKA48351
also, it looks like it has two coolers in front of the radiator, i was wondering what those were, and if i had a super duty, thanks.
Old Jun 6, 2004 | 03:47 PM
87carbed's Avatar
87carbed
i forgot, it also has a really rough idle, almost like the timing is off, thanks.
Old Jun 6, 2004 | 03:52 PM
sglaine's Avatar
sglaine
Posting Legend
I would say if is an automatic they are coolers for the trany. How many miles on the truck? I can help with a little more info.
Old Jun 6, 2004 | 04:00 PM
87carbed's Avatar
87carbed
it is an automatic, and it is hardly used, only 30,000 miles on it
Old Jun 6, 2004 | 08:34 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Follow the cooler lines back to where they go... On my old Chevy 454 dually I had one cooler for the tranny and one for the engine oil.
You can look up your VIN number and door sticker code info in the 'tech articles' section of this site (link in the upper right hand corner of page) and find out for sure what tranny and axle ratio/differential type you have.
If your auto trans is a 3 speed without overdrive, it will be a C6. I don't know if they were using the E4OD yet in 3/4-tons in '87. Your rear axle is likely a 10.25" Ford and could be full-float or semi-float, depending on the truck's GVWR and rear GAWR. Trucks over 8600 lbs GVWR should be full-float. Most had axle ratios of either 3.55 or 4.10.
