Explorer engine swapping...
Old Jun 6, 2004 | 12:53 AM
rick90yj's Avatar
rick90yj
I have a 91 F-150 with a toasted engine. I also have a 97 Explorer short block (no heads or intake, or accesories on the front of it.) What will I need to complete this swap? I do know the motor is a roller motor, and it doesn't have a distributor (some sort of pickup on the front of the crank.) Will the heads from the 91 fit the 97 block, and will they work OK?
Old Jun 7, 2004 | 10:26 AM
CobraXP's Avatar
CobraXP
I take it we are talking about a 302 block?
Yes, you could use the shortblock from the Explorer and swap most of the parts pretty easy - depending on what all is hurt on the F150. Are you planning on using the electronics from the F150?
Old Jun 7, 2004 | 07:09 PM
rick90yj's Avatar
rick90yj
parts...
I'm figuring on basically taking the bad engine out, and just swapping parts until it looks like the original did. I know the Explorer engine has a roller cam, so I'll have to use the firing order (distributor) for that. Anything else I should be aware of?
