For the past year there have been times when I go to start it and it would sound like the starter was taking off on its own. I'd have to let off the key and try again. Usually started right up on the second turn of the key. Today I went out and all I get is a *click* *click* when I turn the key. All power accessories work good. Would this be the starter? All info is appreciated. Thanks.
It is probably the starter. Next time you get the *click click*, crawl under your truck with a hammer and tap the starter a few times. Then try to start it again. If it doesn't start try hitting it a little harder. If it still doesn't work it could be your battery cable from the solenoid to the starter. Good luck.
I love cheap fixes. Especially when nothing is spent. I jacked up the truck and crawled underneath. Turns out that the starter was just barely hanging on. I cranked the bolts tight and it fires right up. *whew*
