Need Column Help
Old Jun 5, 2004 | 08:32 PM
JasonR's Avatar
JasonR
Thumbs up Need Column Help
I'm puting my column back together after replacing the bearings. I need some direction on the sequence of parts from the end of the column (wheel end) to the steering wheel. I have the smaller bearing pressed into the housing but I can't remember how things go from there. I might be missing something. spring, metal sleeve with lip, c-clip, plastic collar for the signal turn off. I tried putting the sleeve on then spring then clip setting it in the most farthest groove but there is a 3/4 inch slop between the clop and spring. So I compressed them to the next groove. It was really tight and the clip doesn't want to stay in. So I put the plastic collar after the spring and put the clip in the farthest groov again with a little compression and it fits ok but I am almost certain this is not how it was and I think the signal switch won't even touch it know. If anyone have a good detailed diagram it would be helpful. I did a search and the one posted from the Ford Parts sight is to vague. Thanks for the help. I like the site but it seems to lock up on me alot?
