Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
firstgen lightning
Old Jun 5, 2004 | 01:30 PM
kyr8bg's Avatar
kyr8bg
firstgen lightning
i just bought a first gen lighning 5.8lt the guy put on msd6al headers, pullys and intake spacer, but i doubt if he had it tuned after that, its a strong eng but it should be stronger, also it has a rough idle and a dead miss plugs, wires, cap/rotor check out good is there a good way to check injector fire farily easy?? and is there a good chip out there for this truck ? HELP!!!!!
Old Jun 8, 2004 | 04:22 PM
run351's Avatar
run351
There are a few common causes which seem to produce the idle problems in these trucks.
1) Intake leak (somewhere) which causes surging also.
2) PCV valve (back of motor) loose causes rough idle and stalling.
Is your Check engine light on?? is it functional?
as for the power loss, the headers can cause a tq loss. We ended up adding alot of timing to make up the tq I originally loss in my truck after the exhaust modification.
You have alot of chip options, but truthfully you need to find a local tuner to you and have the truck dyno tuned for optimal results. A standard chip is set to to modify settings for a stock truck, the custom tune wil take into consideration your modifications.
Old Jun 8, 2004 | 06:00 PM
kyr8bg's Avatar
kyr8bg
thanks man and yes i checked the pcv valve and it was loose and the hose was cracked aswell, i found a bad plug wire as well the check engen light does work however i removed the egr valve so the light stays on now but prior to that it was off thanks for your help which chip is a good one that you can adjust ?? about how much hp does that eng stock produce??
Old Jun 8, 2004 | 06:44 PM
run351's Avatar
run351
when it comes to the tuning the 1st Gens you have a couple good options.
I have dealt with both owners and if you talk to them they will take care of you.
1) www.teamjdm.com
2) http://www.powersurgeperformance.net/
good luck
hilgerbeast
Mar 26, 2012 08:39 PM
ZFLASH
Feb 18, 2012 02:50 PM
isx7to7
Oct 3, 2010 07:13 PM
spatts
2004 - 2008 F150
Apr 19, 2009 07:55 PM
