Sponsored by: Real Truck
shock question...
Old Jun 5, 2004 | 06:48 AM
klp's Avatar
klp
shock question...
I have been loooking around on E bay, will shocks from a 4wd 250 r 350 fit my 2wd 250??? I plan on putting the 4" blocks in the rear, don't know if that matters either. Thanks in advance...
KP
Old Jun 5, 2004 | 01:38 PM
FF-Paramedic's Avatar
FF-Paramedic
Everything that I have found says that the stock F250 and stock F350 use the same shock.
If you swap out the OEM 2" spacer blocks for the 4" spacer blocks from an F350 you essentially have an F350 rear suspension although it doesn't change the vehicle certification as far as GVWR is concerned. The ride heights should be comparable between the two.
Where you might run into differences is in shocks from lifted applications due to shock length and travel.
