adjustable master cylinder pushrods
Old Jun 5, 2004 | 01:22 AM
2ndmouse's Avatar
2ndmouse
I found the napa part # for those adjustable rods.
its 615-1116
thats for a clutch pushrod but with a little work with a round file, you can pair it with an MC from a 67 f250 and it will bolt right on to a 65 f250. The one I picked up at advanced had no pushrod with it, and this napa universal part worked like it was made for it. (almost)
After I bolted it to the pedal, i backed it off enogh to put the pointy end in the MC pushrod socket, then adjusted it out till the pedal was more or less snug. with no fluid, the rod goes in a bit more than 1" (i marked and measured) and with fluid and sealed, the rod moves at most 3/4 of an inch in first pump. As I read the instructions well within the limit of the pistons stroke.
there it is, a no cut no fuss alternitive for converting a single MC to a dual for the 65 and I imagine the 66 as well.
I did comapre side by side the MC for a 67 mustang, a 68 galaxy and a 69 bronco, and the 67 f250's manual drum brake MC (you must ask for the manual drum brake one) is bigger, and heavier than the others, which come with a pushrod that will need cut and fixed.
why bother when you can get a rod off napa's shelf for 5 bucks?
I hope that helps someone!
Old Jun 5, 2004 | 09:51 AM
banjopicker66's Avatar
banjopicker66
Woold you mind contacting me off-line? (Your profile disallows e-mails thorugh FTE.)
My e-mail address is banjopicker66 at hotmail dot you know what.
Old Jun 5, 2004 | 01:53 PM
2ndmouse's Avatar
2ndmouse
I didnt know itr wouldnt let you send me email, i changed it and sent you an email BP.
Dave145
Dec 22, 2017 01:00 AM
DSparksF250
Nov 7, 2016 11:06 AM
F-250 WARHORSE
15
Aug 9, 2016 09:51 PM
alchemist1
Jun 1, 2012 11:38 AM
BruceF350
Feb 28, 2010 01:55 PM
