Can someone explain any steering and alignment problems with these trucks. I have a f250 4x4 and a few people have stated I will never be able to keep it aligned especially if I take it mudding. What is the problem with the ifs suspension and is there a permanent fix? Thanks...
All Ford TTB front axles have a tendency to drift alignment. There's nothing you can do to stop it. It just happens.
There are a couple 'fixes'. One, go to a Firestone dealer and ask for a lifetime alignment. For $160, they will keep your truck aligned as long as you own it. It's a good deal. Or, you can swap in a solid front axle. This will also cure the TTB alignment issues.
