Down Pipe 94 Td
Old Jun 4, 2004 | 08:31 PM
94f2507.3td's Avatar
94f2507.3td
Question Down Pipe 94 Td
WITCH DOWN PIPE SHOULD I USE &WHAT SIZE?? WHAT AIR INTAKE IS BEST? INSTALLING LUK SMF CLUTCH KIT THI WEEKEND SHOULD IGET DOWN PIPE FIR ST??
Old Jun 4, 2004 | 10:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I am assuming you have a factory 7.3 IDI turbo.
Without a new outlet flange you can only put a 2.5 inch downpipe on the turbo.
You need to get in touch with ATS to get a new turbo outlet flange for the 3" pipe.
They also are a good place to get the 3" downpipe.
If you are pulling the motor to install the clutch, it would be a great time to fold the body seams over to make room and install the 3" downpipe.
