Knocking
Old Jun 4, 2004 | 12:55 PM
mduranko's Avatar
mduranko
Question Knocking
I’ve got a ’90 Bronco 5.8L, its got a knock in the bottom of the engine and the rear main seal is leaking. Now I’m wondering if these problems are related. Do you think that the main bearing are worn and need replacing? And if they do, how do I go about sizing the new ones on a stock engine that has never been rebuilt? All help and comments needed.
Old Jun 5, 2004 | 08:36 AM
jwtaylor's Avatar
jwtaylor
I doubt they are related but any thing is possible.
You will have to determine the source of the knock and go from there. If its a spun bearing you'll need to check the condition of the crank and determine if machining is required and how much, then you can determine what replacement bearings you need to use. Good luck
Old Jun 6, 2004 | 01:01 PM
fordberg's Avatar
fordberg
What kind of knock? How loud? How deep? Does it sound like it is going to blow up?
Old Jun 8, 2004 | 10:26 PM
Janet40's Avatar
Janet40
Is it a wrist pin knock? or a connecting rod knock?? Try this, Rev the engine up and if it gets worse, you may have a Piston skirt cracked. If it stops while reved up, sounds like a thrust bearing issue, and that would cuase rear seal problems if that is it. Another mistake many people make is by using a spark plug that has to long of a reach, and that will definitely cause a knock. ....Janet
