Need Help Quick
Old Jun 4, 2004 | 11:00 AM
RETTE's Avatar
RETTE
Need Help Quick
Pulled In The Drive Way The Other Day Truck Stalled Wouldnt Start Till The Next Morning. Took It To The Dealer They Said It Is Showing A P0603 Code And Said That Meant I Had A Performance Chip In It. Problem Is I Dont Have A Chip In It. Told Them That I Bought It A Year Ago From Ford Used If There Is A Chip In It I Bought It That Way. Guy Kept Insinuating That I Wasnt Telling Him Everything. Anyone Have Any Like This Happen To Them?
2002 F250 Sd Lb Crew 7.3 36,500
Old Jun 4, 2004 | 11:25 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That code can be set by nothing more than disconnecting the batteries. Clearly your dealer is on a witch hunt, and evidently doesn't know (or care) too much about you or your truck. It's a shame that has to happen, but it does all the time.
Find the closest International dealer and get a camshaft position sensor to put in it.....johnsdiesel has a couple of good links on part numbers and how-to's.
Old Jun 5, 2004 | 08:23 AM
johnsdiesel's Avatar
johnsdiesel
Thanks for the introduction cookie88.
Here you go:
CMP Sensor Location and Part #
CMP Sensor Removal/Installation
