Sponsored by: Kumho
Tire Question
Old Jun 3, 2004 | 12:33 AM
txag96's Avatar
txag96
Tire Question
I'm new to the board and hoping to get some advice on tires from you guys.
I have a 2001 F250 Powestroke 4x4 super cab with Wrangler AT/S 265/75/16E tires. I no longer have the need to pull anything and I'm thinking about switching to a BF Goodrich All-Terrain T/A KO 285/75/16D.
Can I safely switch from an E ply to an D ply? If I'm not going to be towing anything is there anything wrong with using a D ply?
Thanks for the help.
Old Jun 3, 2004 | 12:38 AM
95-F-350-4x4's Avatar
95-F-350-4x4
Yeah I run that same tire on my 95 F350 and haven't had any problems whats so ever. Its a great tire go for it! I'm running them on the stock wheels as well.
Old Jun 3, 2004 | 06:31 AM
txag96's Avatar
txag96
Old Jun 3, 2004 | 11:10 AM
mrwizard's Avatar
mrwizard
Look at the maximum weight rating for each tire. I bet you will find they are almost identical.
Old Jun 4, 2004 | 04:58 PM
Rambo's Avatar
Rambo
As long as you aren't towing or carrying heavy loads in your bed, you could switch down to a C range tire and be fine, and probably get a smoother ride out of it as well.
Old Jun 4, 2004 | 06:28 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I'm running 33x12.50-16.5 load range D BFG AllTerrain KO's on 10" wheels on my F350 with no problems. I pump them up to max pressure when I have a load in the bed. If I had a bigger heavier camper I would want tires with a higher load rating, but for me they are fine.
Old Jun 7, 2004 | 01:09 PM
txag96's Avatar
txag96
95 and SoCal,
What pressure are you running them at?
Old Jun 7, 2004 | 05:29 PM
95-F-350-4x4
I run mine low because I like a smooth ride and they are worn out anyways and need new ones. I'm running them at 35-40 psi. I hardly carry anything heavy in the truck anyways. I will inflate them a little more when its loaded. I need to redo my suspension bushings. I was looking at those things the other day and they are shot and will replace them as soon as I get my lift.
