Speedo problem
Old Jun 2, 2004 | 04:39 PM
theafus's Avatar
theafus
Speedo problem
I have a 89 F150 with a 302 4x4 the speedometer at around 65 to 75 miles an hour isw really loud vibrates and surges and bounces between the actual speed and ten mile per hour slower is this the cable or the speedo? After about 75 it quites down and stays in one spot until the RPM's kick up when the tranny downshifts or something then it does it again until it shifts back down.
Old Jun 2, 2004 | 09:09 PM
MustangGT221's Avatar
MustangGT221
Could be the cable or the gear inside the granny, its only plastic.
Old Jun 3, 2004 | 02:39 PM
theafus's Avatar
theafus
If it was the gear would it do it at all speeds or just between ceratin ones? does the speedo come off the tranny or transfer case in a 89 F150?
Old Jun 3, 2004 | 03:53 PM
Jimmy Dean's Avatar
Jimmy Dean
I was told it is off the rear axle.
Old Jun 3, 2004 | 10:34 PM
FordPerf300's Avatar
FordPerf300
I'd say the gear is starting to slip at high speeds causing this.
Old Jun 4, 2004 | 03:04 PM
theafus's Avatar
theafus
Thanks where exactly is the gear located and how much is a new gear, is it in the t-case like chevys or in the rear axle? Thanks again
