Ford vs Fram
Old Jun 1, 2004 | 08:21 PM
lamarafronhe's Avatar
lamarafronhe
Ford vs Fram
Has anyone had problem with fram oil filters in thier Ford Vehicles??
I have a 91 explorer with 273,000 + mileage on it I parked it back in Aug 03 due to the fact I bought a 2000 Explorer. My wife needed a car because she blow the trans in her Tausus wagon which is another story anyway I put the 91 back on the road for her. She drove it about a week and while returning home she said the oil pressure dropped to 0 psi After towing it home I check it out and she was right.I was talking to a friend that owns his own garage he ask if I had a Fram filter on and that I should take it off if so and then check oil pressure I did and put a motorcraft filter on My oil pressure when back up to about 35 psi the only problem is from the time the oil pressure drop till my wife got the thing stop it toke the bearings with they are knocking like crazy
Old Jun 2, 2004 | 05:53 AM
srercrcr's Avatar
srercrcr
I have used Fram in GM and Ford vehicles for thirty years...no problems.
Consumer Reports tested oil filters some years back, rated Fram numero uno!
Old Jun 2, 2004 | 05:59 AM
K2JJB's Avatar
K2JJB
Though it is not a professional study, there is some good reading (at least I think so) about the make up of different brands of filters at the following web site:
http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html
the author of the site then draws conclusions based on that info on the following page (mind you these are the conclusions of the author of the web site and, as such, are just opinions):
http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilters.html
Old Jun 2, 2004 | 02:25 PM
LV Dan's Avatar
LV Dan
Stopped using Fram Filters
It is true that Consumer Reports tested the Fram filters and the came up on top. But that was a long time ago and before the new SAE standards for testing.
While I used Fram oil filters on my '99 Explorer since the first oil change, I was noticing some oil pressure problems on start up. After some research, I discovered using Fram filters can cause the problems I experienced.
After reviewing the study at http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html,
I have now stopped buying Fram.
I should also say that when Consumer Reports did the oil filter tests, Motorcraft was up on top, too. But according to the website, Ford changes manufacturers sometimes.
