brake upgrade?????
Old Jun 1, 2004 | 05:45 PM
drvsamini's Avatar
drvsamini
brake upgrade?????
i am trying to replace the rotors on my 94 two wheel drive f-150. does it matter if i have abs front or rear when i replace these rotors? if so than how do i tell? thank you.
Nick
ps i want to put a larger diamter rotor on the front, does anyone see a problem with this? and does anyone know where to get slotted rotors or some sort of nice aftermarket performance rotor for under 150 a pair?
thanx again.
Old Jun 1, 2004 | 06:28 PM
MustangGT221's Avatar
MustangGT221
I havn't seen any larger rotor upgrades for our trucks, and if u did you'd need bigger rims (which means new tires) as well as calipers and pads. I have some drilled rotors and hi-po pads..helps a bit.
Old Jun 1, 2004 | 06:37 PM
drvsamini's Avatar
drvsamini
what brand pads and rotors?
Old Jun 2, 2004 | 08:50 AM
drvsamini's Avatar
drvsamini
and what about a decent caliper? i'm thinking atleast a two piston caliper would be a decent upgrade to my stockers? as far as me using a larger size rim if i used bigger rotors, i planned on doing a 17"-18" wheel with 35's or so. after the lift, and so on.
