engine numbers
Old Jun 1, 2004 | 11:54 AM
Reg Wal's Avatar
Reg Wal
engine numbers
Can someone tell me what these numbers are 2GA 6015 6? They are on the left side of an old 6 engine I got with my 42 truck. I can't find any numbers on the bell housing and was wondering if these are the numbers. They are cast into the block.
Old Jun 1, 2004 | 12:15 PM
46fordtruck's Avatar
46fordtruck
6015 is a number for an engine block...from what your numbers say, you've got what is called the G series 6 cylinder. This engine was made from '41-late '47, when it was replaced by the H series 6 cyl.
Old Jun 1, 2004 | 01:19 PM
Reg Wal's Avatar
Reg Wal
Thanks 46, that confirms my thoughts. I also found this number on my 41 frame, BBI8-5967800Y. Have not been able to locate a number yet on the 42 because of the batt tray. Not sure how to get it out without taking the fender off and I am not ready for that yet. I did find a number on the trans but have to clean first to read. I thought numbers were on bell housings too?
Old Jun 1, 2004 | 03:27 PM
46fordtruck
Yes, the VIN was stamped on the bellhousing...I prefer the number on the frame since it's a way better gaurantee that it's the truck's VIN since the transmissions often get swapped out at some point in the trucks life. There is a bolt that is on the side of the frame rail, between the frame rail and the inner fender panel that helps stabilize the battery tray.
sgt.bigjim
Nov 20, 2013 09:36 AM
kcmark
Oct 31, 2010 01:22 PM
Power_age
3.8 & 4.2L V6
Oct 28, 2006 10:58 AM
lavcheech
May 21, 2005 02:56 PM
stantojl
1997 - 2003 F150
Mar 10, 2004 10:49 AM
