I went off-roading this weekend (had a total BLAST - pix HERE ) and need to make some adjustments. I have only 3 things that are a problem almost every time I start crawlin' over rocks.
1. Tie rod keeps getting smashed/bent
2. Rear shock mounts get banged up
3. Radius arm brackets are too low.
The radius arm brackets aren't a real big problem, but I'm gonna look into longer ones with different brackets.
Someone had suggested looking into flipping the rear axle upside down and re-welding the spring perches on. This would put the drive shaft another 8" higher as well as the shock mounts. Anyone try this before? I don't think the gear lube will get to the pinion bearings if I flip it.
The tie rod can be straightened and reinforced, but it still hangs low. I saw a GM truck with a D44 front axle and he put the tie rod on the TOP of the knuckles. I think my knuckles have tapered holes so I don't know if it'll work. Anyone ever try THAT?
Any thoughts or comments would be greatly appreciated.
2) cut the shock mounts off and re-weld them to the top of the axle ppl do this all the time (never flip an axle over unless you research it and find you can do it. the housing is designed to flow gear oil into the bearings and around the ring gear/pinion gear for lube) plus it is easier to re-locate your mounts rather than flipping your axle over
3) make a set of radius arms that are long enough so you don't have to run drop brackets. that or make bracket that will raise your radius arm up where it connects to the axle (i dunno if that would work, i literally just thought of it)
-cutts-
To flip your tie rod you'd have to drill out the tapered part, then weld in another tapered insert. I know a place called GoferIt Offroad sells something like that for jeeps...dunno about your application.
You cant flip your axle because then it will turn the wrong way-your front and rear axles will be playing tug-of war. Some GM's came stock with the tie rod on top of arm, are you running 8lug axles?? if so, you could switch over to the GM setup from the knuckles out- might want to investigate ford tie rod fittment to GM arms first.
i wanna play i wanna play!!! that one hole with the 2 trucks in it looks fun to go through....where this place located? i have a 78 that i think can go through it!!
JeremyH,
I've seen those inserts too, but I can't remember where. Thanks for the company name, I'll look them up
wyldstallyn73,
It won't spin backwards because I'd flip it about the drive shaft axis, not turn it around and use it on the front.
dixiemudder04,
That place is in northern Wisconsin about an hour from Green Bay. The big field with all the mud holes is what we call the Playground. It is a blast, and getting back to it is even more fun.
Rotating your axle around the driveshaft axis would mean you have turned the axle around and the tires WILL spin backwards. But hey, throw it in reverse and off you go! You'd have quite a variety of reverse gears.
I have seen those tapered inserts in my wild horses catalog- it's an early bronco supplier but I think the inserts were for putting fullsize ford tie rod ends on top of early bronco arms so they should work.
