Rear end code
Old May 31, 2004 | 11:46 PM
77lowrider's Avatar
77lowrider
Rear end code
I tried doing a search for the code deciphering on the rear end tag, with not much success. Can someone decipher this for me. I basically need to know what "kind" of rear end it is: Dana 44, 60, etc. I believe it came out of a 3/4T CC SB, but can not say that with confidence. Thanks, here is the code.
354-D6T5-GA-603725-18.
'bout the only thing I could get out of it, is that it has a 3.54 gear ratio.
Old Jun 1, 2004 | 06:58 AM
BigShelby's Avatar
BigShelby
That I believe is the part number. The D6 portion means it's for a '76. Look on the axle housing for a metal tag attached to one of the bolts. This is the rear end ID tag. Find the numbers and post them. Do a search on this site for rear end ID and I'm sure you will finds tons of info.
Old Jun 1, 2004 | 08:20 AM
77lowrider's Avatar
77lowrider
That is the numbers from the metal tag attached to one of the bolts.
Old Jun 1, 2004 | 08:46 PM
BigShelby's Avatar
BigShelby
OK then you have the 3:54:1 open rear. D6T5-GA might be the bearing code but looks more like a part #. The other numbers might be a build date or production number. The only really important number is the axle ratio and whether it's a limited slip open rear.
Old Jun 1, 2004 | 09:14 PM
asigalet's Avatar
asigalet
If it is out of a 3/4 ton truck (8 bolt hubs), then it should be a dana 60. It will not be anything smaller.
Old Jun 1, 2004 | 10:00 PM
77lowrider's Avatar
77lowrider
kewl, thanx guys
