Wicked Wheel Install
Then comes the test drive.
Very disappointed. Yeah, it has a pretty cool sound, but nothing else. Did not gain anything in the low end, lost some if nothing else. I have a 4" DP, which is why I installed it in the first place. (was under the impression it helped low end) Max boost dropped from about 20 to around 16 (big difference!). Haven't pulled the trailer yet to see if it helped by turbo surge.
I will run it for a bit, not anxious to get the original one back in (yet) (still sore from the install) and see if anything changes. At least the second time around will be a bit easier.
By the way, good job to the guys at Dieselsite.com, had some good accurate instructions with the wheel.
If I go the week and still not pleased, anyone interested in a slightly used wheel for $40?
Your WW will help signifantly while towing to get rid of the surge. Your boost should run about the same. Also the WW is better impeller as it hold up better to higher rpms.
By the way keep an eye out for oil leaks for the next week or so. I and a few others have had pedistal leaks after the install and we didn't even remove the pedistal. but, when moving the turbo around to put it back it sometimes will break the o-rings loose and you will lose the seal hence a leak.
Fire Rooster
I saw somewhere a device to make where you can pressurize your system to check for leaks, guess I had better try it. Would be cool if I could get my boost top end back up, cause I did like the way it sounded.
If not, out with the new, in with the old, maybe go down the chip lane.....
Oh, by the way, Happy Memorial day, Bless our Fallen!!!!
I think part (or all) of the reason you have lost some boost is because you don't have a chip. You have an open intake, a wheel, and a big exhaust, so you have plenty of airflow to support some power....but no fuel to make use of it. I doubt there is a load heavy enough to make your turbo surge in it's current state....EGT's will never be a problem either.
