Sponsored by: Real Truck
Quick Question...Torque Specs
Old May 30, 2004 | 09:59 PM
twoballsleft's Avatar
twoballsleft
Exclamation Quick Question...Torque Specs
What's the torque specs on the front and rear U bolts for a F350 4x4 PSD?
Old May 30, 2004 | 11:23 PM
believer45's Avatar
believer45
You don't give the year of your truck. I have info on 1995's
From factory 1995 factory manual:
Front on 4x4:
Shackle bolts 120-150 lb-ft
Spring eye bolt 120-150 lb-ft
U-Bolts 85-120 lb-ft
Rear without overload springs (spring on top of axle tube, u-bolt nuts on top)
Front spring eye bolt on rear spring 83-113 lb-ft
Rear spring eye bolt on rear spring 141-191 lb-ft
U-bolts 141-191 lb-ft
Rear with overload springs (spring on top of axle tube, U-bolt nuts on bottom)
Spring eye bolts, both ends 157-212 lb-ft
Hope this helps out.
Dave / Believer45
Old May 31, 2004 | 04:15 AM
fitter565's Avatar
fitter565
Twoballsleft, On my 04 F250 the fronts are 120 ft/lbs and the rear is 140 ft/lbs. I hope this helps.
Fitter
Old May 31, 2004 | 09:29 AM
twoballsleft
Duh...yea it's an 04...120 on the front?!...no wonder it's "clunking"...they are at 25-30 right now. What is going on with Ford?
Old May 31, 2004 | 11:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
There are a number of threads on this issue........let us know if it cures this problem.
Old Jun 1, 2004 | 03:02 PM
twoballsleft
Looks like a wrap...torqued the front and rear u bolts to spec and problem solved...so far.
Old Jun 1, 2004 | 09:59 PM
99f350sd's Avatar
99f350sd
Even when you do a spring change they loosen up from time to time.....maybe when they tightened them they wern't seated properly or it was a friday...hope it fixes your problem....
