1978 - 1996 Big Bronco
Big Block Swap
Old May 30, 2004 | 09:47 PM
rgowan1's Avatar
rgowan1
Question Big Block Swap
I have a 1983 full size Bronco with a straight 6 and I want to go to a 460 BB...What all with that require? I know I need a BB transmission But will that bolt up to the stock Transfer? If not will I need a new transfer as well or can I just go with a different coupler?
Old Jun 10, 2004 | 04:30 PM
calazo's Avatar
calazo
Arrow How rude, nobody has replied yet....!
Sorry dude, nobody has replied to your thread. I am also considering an engine swap from an I-6. It is my understanding, as you point out that for a 460 (Big Block) you would need the equivalent tranny (i.e. C-6, C-4, etc...) with the Big Block Pattern & Bell Housing to be able to bolt it into the new engine. I would advise you to get the tranny from a 4x4 donor truck so that it fits nicely. However, I'm telling you, a big drop in MPGs will result from that swap, not that I wouldn't be keen into doing it myself (if I had better income, that is...). good luck!
Old Jun 14, 2004 | 04:15 AM
battered_bronco's Avatar
battered_bronco
first my same ol'gripe the phrase "big block" denotes a chebbie engine ford never used those terms you are most likely thinking of a 385 series/family commonly(recently) the 429/460 for the love of god do not call a 460 a chebbie
but back to the point the 300 (240/300's common name is the Big six) is the second best truck motor deffantely keep and spend the money to improve it ya know intake/exaust/carb(?)/cam to inprove the giddie-up effect lol
Old Jun 14, 2004 | 05:51 PM
Kemicalburns's Avatar
Kemicalburns
or you could move up to a 351, stroke it to a 393. you will be able to keep the same tranny all you would need is the correct motor mounts and of course motor stuff an your set. mpg would be better then a 460 and probably about the same or a little less then the 300-6.
Old Jun 16, 2004 | 03:44 PM
Outlawwv's Avatar
Outlawwv
i'm considering the same swap myself -- am searching for the donor now so i can get all the pieces brackets etc -- let me know what you find out and i'll do the same
Old Jun 21, 2004 | 10:47 PM
battered_bronco
you could scrounge a 400 fmx "budget" bore and stroke it to 427 no specilty rods/crank a few thou under decked but not advisiable
now big six is a v~nice truck motor
but to go to a 460 .ya need(as far as i know mounts complete motor with all accesories computer header exaust tranny transfer case yoke to convert the different driveline size maybe
scrounge some of the proformance "big six" forums to see what can be done with them there are even super charger set-ups as i recall
give the 6 a chance
ps oh ya you prob need a drive shaft and the axle yoke not the transfer case yoke
Anthony Polsinelli
Jan 18, 2016 05:30 PM
vhautomotive
Oct 17, 2015 11:15 PM
Omarzero
Apr 6, 2015 03:41 PM
jhl3
Mar 20, 2015 07:11 PM
1FastGambler
Nov 28, 2010 06:04 PM
