Bronco II Ford Bronco II
Tires
Old May 30, 2004 | 05:50 PM
Avanti's Avatar
Avanti
Tires
Can I run 235 75r 15 vice 205 75r 15 0n a stock non lifted 89 BII? The local Wall Mart has a super sale on the 235 size tires by white letter Goodyear all terrain .
Old May 30, 2004 | 09:12 PM
Ken00's Avatar
Ken00
I don't see a problem with them, the diameter is not much bigger, your speedometer might be a little off.
Old May 30, 2004 | 10:21 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Thats what I run on mine and NEVER had a problem with then.There from wally world too.
Old May 30, 2004 | 10:55 PM
CherryColaholic's Avatar
CherryColaholic
Well i got an 89 b2... i run 31x10.5's just fine. They rub a little on the sway bar when the steering wheel is turned all the way. And before i got new shocks they would rub the wheel wells a little on big bumps. Now with stiffer shocks i can catch air and as long as i dont land on one wheel before the others theres no rubbing at all. Anyway my dad has 235/75s on his 97 blazer and they are a bit smaller than mine.. sooo my point is, those tires will be totally fine, you can even go a little bigger with no problems if you want.
