Serious Problem - Overheating 300
Old Jun 4, 2004 | 05:31 PM
  #31
Nightrain's Avatar
Nightrain
Yep.It had a 185* in it and I replaced it with a 160*.
Nightrain
Old Jun 4, 2004 | 06:19 PM
  #32
bremen242's Avatar
bremen242
It shouldn't be too sudsy.. ? is your truck using any oil at all?
If the flush doesn't work, you'll probably need to get a new radiator or get yours dipped.
if that doesn't do it, I'd try a mechanical gauge to verify the temperature, and I'd think about replacing the head gasket...
Old Jun 4, 2004 | 09:18 PM
  #33
Nightrain's Avatar
Nightrain
Nope,as far as I can tell,it's not using any oil.There's no oil in the antifreeze if that's what you're suggesting.It's just pure antifreeze.I haven't tested it to see how good it was though with one of those antifreeze testers.I'm just going to flush it tomorrow and see what happens.There's a local radiator shop in town,so getting it dipped,(if the need arises),won't be a problem.
I don't believe that I'll have to replace my head gasket.I'm not losing any water or oil,so that should solve that problem,right?
Thanks brother.
Nightrain
Old Jun 4, 2004 | 11:07 PM
  #34
bigbrown84truck's Avatar
bigbrown84truck
the proper cap for your truck (and mine, same motor) is a 13 lb cap, when i put my new radiator in i put a new cap on just for caution (they only cost like 5 bucks). when you drain the anti-freeze out of your radiator i really strongly suggest replacing the lower radiator hose, first of all if you have a clog it could be in that hose since it is the lowest point. Also this way you know the hose won't crap out on you after you flushed and replaced all the anti freeze. also just so you know you dont' really get all of the old coolant out until you remove the lower hose.
Old Jun 5, 2004 | 12:36 AM
  #35
Nightrain's Avatar
Nightrain
Thanks bigbrown.I'll probably get new radiator hoses while I'm at it.I'm not for sure yet though.I'm the type that doesn't fix what ain't broke 99.8% of the time .
Nightrain
Old Jun 5, 2004 | 07:45 AM
  #36
bremen242's Avatar
bremen242
Well, was there bubbles popping up through the radiator when you where looking at it?
Nightrain
16
Aug 4, 2021 07:49 PM
quakerj
Dec 24, 2014 12:43 PM
Dannym
Jul 14, 2005 01:29 AM
Nightrain
23
May 27, 2004 09:31 AM
JDSTONE
16
Dec 17, 2003 07:56 PM
