ignition key from a dealer
Old May 30, 2004 | 04:19 PM
boond0cksaint's Avatar
boond0cksaint
we had a fire and my keys for my 87 mustang and 88 f-150 were burned up. if i go to the dealer with the vin# can they make me another key for each vehicle? thanks in advance
Old May 30, 2004 | 05:42 PM
ALSAIR's Avatar
ALSAIR
Call a locksmith. They have codes for cars. I had one make an ignition key in my drive way by inserting a roller key, took the measurements, went into his van a in 2 minutes came out with a key that worked first try.
Al
Old May 30, 2004 | 05:59 PM
boond0cksaint
i believe those were my only 2 options, i was able to hotwire my rx7, and was thinking about using a dent puller to pull the cylinders. but as long as i have transpo.im ok. about how much would a locksmith charge? ballpark figure
Old May 30, 2004 | 06:09 PM
mrwizard's Avatar
mrwizard
A lot less than fixing the steering column if you rip them apart.
Old May 30, 2004 | 09:30 PM
92lightning's Avatar
92lightning
I had a locksmith come to the house and make a key for my sons camaro. It took less than ten minutes and cost 35$.
