oil filter adapter
Old May 30, 2004 | 10:59 AM
jeter's Avatar
jeter
oil filter adapter
I have a 1993 f-250 7.3 liter non-turbo. I have water leaking out around the oil filter and i was told it was the oil filter adapter gaskets and O-RINGS. how hard is it to replace these gaskets.
Old May 30, 2004 | 01:06 PM
Spectramac's Avatar
Spectramac
The gaskets on the block should be fairly straight forward, but I'd stay clear of the cooler O-rings. They only leak oil. There's 4 bolts in front and 4 in back of the cooler. Take the oil filter off and save it if you aren't going to change oil. Then drain the water, including the left side block plug (if you can get it out). If not get ready for a shower when you pull the cooler bolts and break it loose. You should be able to snake it out without too much trouble, probably have to pull the power steering pump out of the way. I've bought both gaskets from NAPA, just clean the surfaces and put it back together. Be carefull with the cooler itself, try not to disturb the end caps on the tube. You can replace the cooler o-rings too, but they are a real bear.
Old May 30, 2004 | 04:41 PM
jeter's Avatar
jeter
I had to order them through the dealer because NAPA didn't carry them. Those are most expensive gaskets i have ever bought, guess that comes with the territory when you have a diesel. What coolent would you recomend using when i get done. Thanks for the help.
Old Jun 3, 2004 | 03:48 PM
Raised with Ford's Avatar
Raised with Ford
I've fleet is good some recommend going to an dealer and getting it there, to help with any cavitation issues.
RockWVU
Oct 13, 2012 10:23 AM
ralf12
Sep 16, 2010 08:28 PM
homer4111
Jun 12, 2006 09:26 AM
nixonbkp
Jan 23, 2005 01:30 PM
Steve
Jan 18, 2004 06:20 PM
