leaky wheel seal
Old May 30, 2004 | 09:37 AM
stillhuntin's Avatar
stillhuntin
leaky wheel seal
I noticed that a rear wheel seal was leaking on my '85 f-250. Is this something I can fix correctly in my driveway with basic hand tools? What about the brakes? I was told that once they are contaminated with gear oil they will have to be replaced also. Any advice is greatly appreciated.
Old May 30, 2004 | 10:39 AM
85F_150driver's Avatar
85F_150driver
are you sure it is the rear wheel seal leaking? If you Have a leaky wheel cylinder it will look like gear lube when it mixes with the brake dust. easy way to tell is to pull the hub off and check for fluid around the seal on the wheel cylinder or take the cap off your master cylinder and make sure both are about 1/4th of an inch below the top of the m.c.
Old May 30, 2004 | 11:47 AM
fai4g63's Avatar
fai4g63
If you have a full floating rear it should be easy. If you have a LD F250 you have a semi floating rear, in that case you have to remove the diff cover to access the clips that hold the axle in. a little more involved then the FF rear. If gear oil has contminated the brake shoes you must replace them.
Old Jun 1, 2004 | 09:40 PM
stillhuntin
Tore in to the f-250 today. I was able to get down to the seal pretty easily, but, I didn't like the looks of the spindle. It has a scabby layer of rust on the top half from the inside of the outer bearing race, to the raised inner portion the seal runs on. Can I sand the corrosion off to ensure a good seal on the new parts? If not, what are my options? Once again any advice to this rookie is much appreciated.
Old Jun 1, 2004 | 10:19 PM
fai4g63's Avatar
fai4g63
I would try using some crocus cloth to sand the rust off the spindle.
Old Jun 1, 2004 | 10:31 PM
stillhuntin
I'm not going to screw anything up by sanding it. Am I?
Old Jun 1, 2004 | 10:43 PM
fai4g63's Avatar
fai4g63
Crocus cloth is not very abrasive, it should remove the rust with out harming the spindle.
Corkwheats
Feb 12, 2015 06:01 AM
PW_SD
Jun 16, 2011 03:12 PM
DADS4x4
Apr 5, 2011 09:59 AM
triskit16
Jan 2, 2009 03:02 PM
86diesel-
Mar 20, 2006 12:20 PM
