Headlight Problem
Old May 29, 2004 | 11:21 PM
Power Stroke's Avatar
Power Stroke
Headlight Problem
On the X I have, I'm having a headlight problem. The headlights keep burning out. I took it into the dealer and they replaced them. A few days later, they burned out again. So I took into the dealer again and told him and he checked them and replaced and said they were working fine. Then a few days later, they burned out again! What do I do now? I can't drive at night anymore. So what should I do?
Old May 30, 2004 | 08:58 AM
Landyot's Avatar
Landyot
Drive only during daylight hours. (just kidding) Take your truck to a shop that specializes in electrical problems, such as an alternator repair/rebuild shop. Tracking down the source of your problem can be a real pain unless you're experienced and have all the right equipment at hand. After the problem is fixed, I'd go back to the dealer and have them reimburse you for the ineffective work they did ... and take the other shop's electrical analysis/ repair-sheet with you. Good luck with that one.
