Turn Signals
Old May 29, 2004 | 03:59 PM
pstonssuk's Avatar
pstonssuk
Turn Signals
My problem seems simple yet i can't figure it out. After my oil change, my turn signals stopped working. One of the bulbs went out, so i replaced it, then checked all the fuses, and they are fine. What happens is when i put the turn signal lever up or down to activate the turn signal, the indicator on the cluster stays lite, and so does the bulb. nothing flashes. So i have no turn signals. Any help would be great.
Josh
Old May 29, 2004 | 05:05 PM
Egor's Avatar
Egor
If they are lighting up but not blinking, I would guess you have a bad flasher. Should be located in or near the fuse box.
Old May 29, 2004 | 08:36 PM
ATC_250SX's Avatar
ATC_250SX
its in the fuse block and about 3 bucks, thats what it is. most defidently, i keep a spare with me because the cheap mechanical ones dont like traillers, for some reason, but you could try one of the more expensive electronic ones, there about 10 bucks.
