1978 - 1996 Big Bronco
dead 89
Old 05-29-2004, 01:45 PM
moritz1024's Avatar
moritz1024
moritz1024 is offline
Question dead 89
cant get my bronco to run, its gettin gas and has spark. dont no wat else to look at cant imagine all the fuel injectors went bad at once. any suggestions would be great
Old 05-29-2004, 02:01 PM
tigerhawk_212's Avatar
tigerhawk_212
tigerhawk_212 is offline
so it just won't start? it turns over and is getting fuel at the rails?
Old 05-29-2004, 02:09 PM
moritz1024's Avatar
moritz1024
that is correct
Old 05-29-2004, 02:16 PM
tigerhawk_212
if its gettin spark to the plugs the plugs might be bad if this is just something that suddenly happened. Was it running fine and then all of the sudden it wouldn't start? Did you put a fuel pressure gauge on the rails to test the fuel pressure?
Old 05-29-2004, 02:21 PM
moritz1024's Avatar
moritz1024
no, wat shoudl the pressure be? and the plugs r less than 20000 miles, and both fuel pumps and filters have been changed
Old 05-29-2004, 02:26 PM
tigerhawk_212
i think its like 40 or something, but how do you know your getting fuel at the rails if you haven't tested it? Did your bronco run just fine and then not run all of the sudden, the next time you started it up?
Old 05-29-2004, 02:37 PM
moritz1024's Avatar
moritz1024
i no its getting fuel, bcuz wen i took the cap off that nozzle on the fuel rail and pushed the pin in, gas just covered my fingers wen it squirted out lol. and there was more presure i just let the pin go
Old 05-29-2004, 02:42 PM
tigerhawk_212
ok if you didn't, drain out all of the fuel on the rail and then try to start the truck. Then go and push the pin down again and see if there is any fuel in there.
Do you hear the fuel pump buzz when you turn the ignition on?
Old 05-29-2004, 03:01 PM
moritz1024's Avatar
moritz1024
yes the line holds the pressure and it builds up again
Old 05-29-2004, 03:04 PM
moritz1024's Avatar
moritz1024
could the timing be extremely off. i took the distributor out to change the ignition module which wasnt the problem. but b4 i took the distributor out i marked its place and made sure it was at the same exact place it was. but i had to crank the engine to get it in again
Old 05-29-2004, 03:10 PM
tigerhawk_212
so you tested the spark plug wires and all of them are getting spark? if so i would just replace the plugs and see what happened. It has to be something simple, but it could be something like computer went bad, injectors etc , wiring..which i hope it isn't,thats why were looking over these simple things first. somebody else has to have some better ideas
Old 05-29-2004, 04:26 PM
moritz1024's Avatar
moritz1024
all the simple things i went through already now i need real help lol
Old 05-31-2004, 06:12 PM
BurlyBoy's Avatar
BurlyBoy
BurlyBoy is offline
So, it was working fine - then you took the distributor out, put it back in and now it doesn't work?
Old 05-31-2004, 09:49 PM
moritz1024's Avatar
moritz1024
truck is fixed timing was off 180
