flex plate bushing
Old May 28, 2004 | 07:22 PM
RICHMC54's Avatar
RICHMC54
flex plate bushing
hello i"m converting a 1968 f 100 from 3 speed to c6
do i need flex plate bushing?
Old May 28, 2004 | 08:29 PM
Jimbare's Avatar
Jimbare
all alone in the world
you only need the flex plate. the bushing you are talking about, i think, is the pilot bushing for the standard trans. you will have to remove this bushing, the snout on the torque fits into the back of the crank, right where the bushing is!
jim
Old May 30, 2004 | 09:08 AM
RICHMC54's Avatar
RICHMC54
3 speed to c6
thanks for your reply I ment a flex plate spacer ???
Old May 30, 2004 | 11:53 AM
Jimbare's Avatar
Jimbare
sorry never saw one on a ford.
are you talking about the spacer between the motor and bellhousing?
jim
Old May 30, 2004 | 11:56 AM
RICHMC54's Avatar
RICHMC54
seems to me /talking about something to with crank shaft. have no idea. i bolted fex plate on and it seems fine
Old May 30, 2004 | 04:54 PM
Jimbare's Avatar
Jimbare
ford used no spacer at the cranshaft.
jim
Old May 30, 2004 | 08:44 PM
RICHMC54's Avatar
RICHMC54
flex plate spacer
thanks for all your replies, I think Im just going to bolt it(flex plate) to crank see what happens
