ok guys i have another one for ya im getting a pretty good deal on a t-5 out of a mustang (75$) would it work in my truck i have an automatic c6 in there now and i know im going to ahve to do some cutting on it but all in all how hard u think the swap will be if it will even work will the crossmember line up right? are they the same length? and the bolt pattern?? im thinking it is the same but i need to know for certin any answers suggestions or advice would be apperciated!
I think the rear end will make up for the ratios and a buddy of mine had a T5 in a bronco with a 351. Maybe the internal design is different on the ones made for a truck.
The shifter on a T5 is farther back on the trans than a regular truch trans; it will probably be right under the seat. A T56 has the shifter almost exactly as far from the front as a T5 and a T56 requires some seat changes and a funny bend in the shifter to work right.
What year is your truck? If it's a late model with EFI then the PCM to run the E4OD is readily available and will plug into your wiring harness. If it's an older truck, you may need to look at other options. There are bolt on OD units available from gearvendors and US Gear, but they aren't cheap.
the truck i have is an 81 carbed 300 pre computer it has no elertical or computer parts other than the standard elertical parts would the c4 be the best bet?
Hey all, I'm new to this forum and have a 1990 F150 with a 4.9 and an E4OD trans. The trans is a bit loose and I have little if any low end torque. SAURIAN mentioned a "build-up for this trans and I would appreciate any detail regarding what this build-up might involve (parts, sources, etc) ??
