1978 - 1996 Big Bronco
Mirror Bolts
Old May 28, 2004 | 05:18 PM
Boss50's Avatar
Boss50
Mirror Bolts
What's the trick in getting those mirror bolts off? 3 broke and the other spins. I need HELP.
Old May 30, 2004 | 10:17 AM
broncochris's Avatar
broncochris
ideas to help remove
The bolts are held by nuts that are pressed into the doors. I had to take the door panels off and spray some wd-40 on the inside (some still broke). If you can see the nuts from inside the door, which you should try using vise grips to stop them from turning. Took me a few tries but i got them off. P.S. dont try to just pull the nuts out of the door from the outside. They are cone shaped with a groove built in to sandwitch between the door. It's better to grind the head off the nuts and push them inside the door.
