Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
What's moved?
Old 07-09-2004, 01:01 PM
95_Lightning's Avatar
95_Lightning
95_Lightning is offline
Question What's moved?
On My 95 Lightning's drivers door, the front edge above mid door, has started rubbing the front quarter panel slightly when I open it. The door itself and
hinges are tight and it closes with no problem. This is bugging me...not to
mention paint flaking off the door's edge... any suggestions???
Old 07-10-2004, 07:32 PM
95_Lightning
I fixed it: Found it was 2 bolts that had loosened inside the engine compartment, that
attached the top of the fender well to the body. Tightning them up pulled the metal away from the door & no more rubbing when I opened the door. The potholes and
rough roads from all the rain around here give the truck a good shaking at times....
probably the result over time.
lightning guy
10-06-2001 10:13 PM
Quick Reply: What's moved?
