1978 - 1996 Big Bronco
Changing shocks
Old May 28, 2004 | 12:49 PM
svgearhead's Avatar
svgearhead
Changing shocks
All the shocks on my '79 are shot.
One rear shock leaks oil. For a moment I thought I had cracked the axle...
Is it possible to change the shocks without lifting up the truck body?
When I changed shocks previously, I did that. But because the Bronco is so high, I don't have jacks tall enough.
Thanks!
Ben
Old May 28, 2004 | 01:35 PM
kumabronc's Avatar
kumabronc
I used some blocks of wood and the spare tire jack to raise the truck up by the frame when I replaced mine a couple of weeks ago.
You might find it difficult to get the shock onto the mounting stud because the rubber bushing on the new shock will be tight. A dab of liquid soap and a c-clamp made the job easier.
New shocks sure made a difference in the ride. I replaced OEMs whith about 100K miles on them.
Old May 29, 2004 | 09:10 AM
gman88's Avatar
gman88
You do not have to jack up the vehicle to change shocks. Keep in mind that shocks do not carry any load (unless they are air or load levelers), they just dampen the oscillations from the springs.
You will have to compress the shock (by hand) after hardware is removed to overcome the internal gas pressure of the shock.
Old Jun 2, 2004 | 09:24 PM
BroncoMTR's Avatar
BroncoMTR
Yeah you can do it on the ground. I would liquid wrench everything about a year in advance every day. I ripped a
1\2''stud off the front trying to break a nut lose. Had to have a grade 8 bolt welded into place. It's fairly simple, but prepare for a few stubborn bolts.
Captain Call
Mar 26, 2017 04:47 PM
Outlaw56
Feb 25, 2017 05:22 PM
8vettes
Nov 11, 2015 07:19 PM
quadzjr
Offroad & 4x4
51
Mar 4, 2008 03:59 PM
mountainman101
Jan 12, 2004 05:15 PM
