removing transfer case yokes
Old May 28, 2004 | 10:04 AM
oldhalftons's Avatar
oldhalftons
is swapping yokes from a np208 onto a BW1345 an easy job?
I have access to a impact wrench.
I got a bw1345 from a 3/4 ton truck but the yokes are a little larger than the ones on the bronco.
Old May 28, 2004 | 06:00 PM
FordPerf300's Avatar
FordPerf300
If the yokes will even fit.... it's not to bad to get them off, your best bet is to have someone hold the yoke with a huge pipe wrench and you try to impact it off, or try to get it off with the breaker bar.
Old May 29, 2004 | 09:27 AM
teds74ford's Avatar
teds74ford
You can also lock it in gear to hold it. This way it can be a 1 man job. Make sure you have a thin enough socket. I went to sears and paid $17 for a socket, only to find out that the walls are too thick. I ended up borrowing a snap-on. Ted
Old May 29, 2004 | 09:44 AM
oldhalftons
teds74ford,
Are the yokes pressed on or will they come off after the nut is off with some Pb blaster and a few hammer taps?
Old May 31, 2004 | 06:06 PM
FordPerf300
They should slide right off, unless the are gummed up, some taps with a rubber mallet will break it free.
