Need interior
Old May 27, 2004 | 10:34 PM
Cruiseomatic's Avatar
Cruiseomatic
Need interior
My truck came from ford with no interior. Was built as a work truck,and I want to have some kind of interior except the dash,What all do I need besides headliner? Because it's bare. It's a 1989 F-150.
Old May 28, 2004 | 12:01 PM
biggreen78's Avatar
biggreen78
I think it depends on what u want to achieve and how much u want to spend. you can get a custom fit carpeting for 100 and up or you could buy the carpet for 20-30 and put it in your self. i put it in with padding for under 50 dollars i used some spray adhesive, not sure if it was the right or wrong way but it looks decent and insulates the truk well. im so cheap that i even used the extra for the headliner. i took heavy duty posterboard adhered the carpet to that and then put it up reusing the stock headliner trim. most of the interior and exterior parts can be bought thru catalogs or online somewhere do a search you'll get tons of info. if u plan on using the truk for the mudd then get some rhinoliner and spray it. cleanup will be a jiff mine sees the mudd sometimes (also my dd) so i didn't want to spend a fortune on carpet, (my investment is in hd floormats) this way if i cant get it totally clean it's easy to replace for cheap good luck...
Old May 28, 2004 | 12:10 PM
Cruiseomatic
I'm not gonna do carpet cuz i dont want it getting torn up. I'm more worried about headliner,behind the seat,things like that.
Old May 28, 2004 | 01:55 PM
biggreen78's Avatar
biggreen78
heck i carpeted behind the seat too and insulated it. i work in chicago, so anything i can do to keep the cold out in the winter helps, cause my heating system isn't exactly reliable. what r u going to do about the floor?
Old May 28, 2004 | 03:57 PM
Cruiseomatic
Leave the vinal like it is,its already got insulation undernieth it. I live in texas so the cold isnt that big of a deal.
