71 429 any good?
Old May 27, 2004 | 10:07 PM
White Monster's Avatar
White Monster
71 429 any good?
theres a 429 in my local paper for a real good price that claims to have 400hp
the guy said it was out of a 71 torino. is this year motor a good one? what about the heads? would it be decent for my 85 f250 4x4?
Old May 28, 2004 | 03:27 AM
DeenHylton's Avatar
DeenHylton
You'll need to buy premium fuel to run it as all 429's had at least 10:1 compression or higher.
Also remember that 1971 and earlier Fords (as well as other MFG.'s) rated their HP at the flywheel...your 429 being 360 HP, while the very next year the HP ratings were net...208 HP. Now they did drop the compression to 8.8 :1 but that no where near accounts for the differance of 152 HP. In other words do not take the claim of 400 HP to seriously unless they have actual dyno figures from that engine.
Just my 2 cents worth...
Deen
Old May 28, 2004 | 10:46 AM
DT 466Man's Avatar
DT 466Man
Whats the difference between net and fly wheel hp?
Old May 28, 2004 | 11:43 AM
Tiremine's Avatar
Tiremine
DT,
He's probably talking about rear wheel HP. I have a 68 429 in my truck, I like the engine but forget MPG. It makes pretty good HP. Pushes my 4000lb brick 8.40's in the 1/8. Bad thing is the heads, the flow numbers really stink. Mostly due to the big bump in the exhaust runner. The upgrade to aluminum CJ heads is WAY out of my budget.
Tiremine
Old May 29, 2004 | 12:39 AM
scroob's Avatar
scroob
Tiremine, if those are the stock heads, they will respond really well to porting. I've never heard anybody say the flow numbers stink, not even bone stock ones. Those are the legendary "D0VE" heads (C8 - D1VE) that are greatly sought after.
Old May 30, 2004 | 03:09 PM
Tiremine's Avatar
Tiremine
scroob,
Check out this site.
http://users.erols.com/srweiss/tablehdc.htm\
It lists head flow number for every engine you can imagine. Even ported the cast iron heads stink.
Sorry
Tiremine
Old May 31, 2004 | 06:42 AM
Tiremine's Avatar
Tiremine
Hey guys,
I want to back up before I make enemies. All I'm saying is that by the time I pay for a professional port job on the iron heads I could buy aluminum ones that flow better and take 100 lbs off the front end.
My $0.02
Tiremine
Old May 31, 2004 | 07:08 AM
baddad457's Avatar
baddad457
If it's a 429 out of a Torino, then you're looking at a 429 CJ or SCJ. If so then, don't even think about opening up the intake ports, they're big enough to store your extra baseballs in now. What do you call a real good price?
Old May 31, 2004 | 11:22 AM
scroob's Avatar
scroob
"It lists head flow number for every engine you can imagine. Even ported the cast iron heads stink. "
I'm sure all the people running 500+ HP 385's with the D0VE heads will be glad to hear their heads stink. What are you going for - 800 HP? Once again, it's a question of application.
From the site: "Bigger is not always better (Highest flow numbers and/or largest port volume). -- Velocity is just as important.
# We want the best flow number's with the smallest volume and the highest velocity."
The numbers given for the D0VE-C heads compare very favorably with the one's listed for the Kaase heads. Kaase is pushing the envelope on 385 series performance.
