4x4 drivetrain question
Old May 27, 2004 | 09:38 PM
k Randle's Avatar
k Randle
Question 4x4 drivetrain question
Hello
I just bought a 76 3/4 ton chasis for my 77 body. It is full time 4x4, so my question is can I put big lockouts on it without to much trouble. It has divorced transfer case. I have been told that it might be a high boy because of the factory blocks under the rear leaf springs. Any truth to that? If not then what makes a highboy? I have also been told that the steering can be dangerous on this truck. It has two hoses that run down to what looks like a cylinder under the axle. True or False. Any info you can give is very Helpful. Wish me luck, because I ordered the conversion kit and the 5.9 cummins diesel. After I install this motor and a new set of gears, I hope it will be a runner. Thanks alot
Old May 27, 2004 | 09:44 PM
ivanribic's Avatar
ivanribic
Howdy! Your highboy questions are answered in the "FAQ" sticky at the top of this forum. Basically it's a 77.5 and older F-250 4x4. If you have a divorced case and leaf spring front then you have an F-250 (what people commonly call a highboy).
The steering is not by any means dangerous but it can be high mantainance and a pain in the butt. It's a hydraulic assist, using the ram to apply pressure to make steering easier. Many people will convert to a regular power steering system. There are many threads regarding this which you can find using the search feature and I believe we have a well written tech article covering the steering conversion also.
Hope this answers a few of your questions. Welcome to FTE!!!
Old May 27, 2004 | 09:53 PM
k Randle's Avatar
k Randle
Thanks
Hello
Thanks for the fast reply. I'm not quite sure what you mean by the "FQA" sticky. Very sorry, but i can't find any info. Can you piont me alittle closer. Thanks again.
The new guy
Old May 27, 2004 | 09:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Welcome to FTE!
That thread everybody is supposed to read at the top of the forum or you can find it here:
https://www.ford-trucks.com/forums/s...d.php?t=102632
Check out the sticky's at the top of every forum.
FAQ = Frequently Asked Questions
