I have a 86 model 6.9 i'am going to rebuild would like to know whatit's takes to make it a 7.3cube any & all info would be great thank you .
david51
85 cc dulley
6.9 c6 354
The 7.3 although very similar to the 6.9 as far as looks there is no real way to make it a true I'm sure you can bore it over and use larger diameter pistons,but the heads are different 7.3's use larger diameter head bolts and the cooling jackets on the heads are plugged on the intake side vs open on the 6.9's.You would be better off finding a good used 7.3 or swapping it with Jasper or Fred Jones, both will accept a 6.9 core for a rebuilt 7.3 but either way your gonna dig deep in your pockets!
>the 6.9 as far as
>way to make it a
>side vs open on the
>in your pockets!
Thanks for the info . But who is jasper & fred jones! also I'am looking for a little more horses !But if all else fails I just get A DODGE & pull what i want!I all read know they will do what i want, thank you.
I've just come out of Powerstroke and into a 2001 Dodge with a Cummins,I've always been a Ford man but that Dodge/Cummins combo
performs great,it's a little noisey,but hey it's a work truck!
