D.O.A. Recon
I found 1/4 of the top of the piston down to the lower compression ring gone!
What was suprising was this motor was immaculate inside with very little crud build-up outside.
I pulled the motor with hopes of honeing the cylinder and popping in a new piston and rings.
After removal of motor and piston I found the cylinder wall scored beyond re-use.
Also I observed the pistons were .040 over and the Recon rebuild plate #167408 affixed to the side of the block.
This motor was about 5 years old!
Over the years I have seen about a dozen Recon motors self destruct from questionable quality components and shoddy machine shop work!
I even bought one once (It was a rush job)
Burned a quart of oil every 500 miles but ran good, re-did the heads, no change.
Had one with a sleeved journal where the rear main seal rode, chewed the seal after 100 miles, sent it back.
The list goes on.
Rule of thumb, "you get what you pay for!"
Steve G.
Steve G.
Recon engines bite big time, used to sell 'em, didn't have a choice. I'd cringe when someone wanted to buy one.
Let's just say that over 50% of them came back for various reasons.
Not just Recon, any high volume rebuilder is going to have a QC problem, can't avoid it, how you going to rebuild engines in mass numbers and have quality at the same time.
Keep all paperwork, receipts, etc.
Maybe your the one that got a good one!
