lol theres alot of questions on this one thread, have you all started by running the KOEO and KOER tests yet? im still trying to dignose mine, it hasnt run right ever sense that last river crossing (FI doesnt like the water)
I had the same problem on an 89 Chevy Cheyenne 1500. I changed the plugs, cleaned the throttle, and replaced the cylinders. The problem kept going on. It ended up needing a new head gasket which solved the problem. I don't know if that will solve the problem on your Ford or not.
i tested the tps usin my multimeter and the chilton book. everythign checks out. Im goin to the lake this weekend and ill test the injectors and fuel pressure when i get back.
From my field experience as a tech, I can tell you that Fords are notorious for having bad MAP sensors and yet not triggering a code. A bad MAP sensor will be worst at idle to light throttle... whenever manifold vaccum is high. The problem is, without an ociliscope, it can be very dificult to test them because they vary frequency, not voltage. You'd be looking for a square wave 5 volt pattern with a high frequency at low vaccum and lower frequency at high vaccum. A service manual can provide you with the frequencies, as I don't remember them off the top of my head. Also, make sure you are getting adequate vaccum to the MAP sensor in the first place, and if you have any doubts, run a dedicated line to the sensor and take a test drive to see if it makes a difference.
Can i just check my MAP sensor with a volt meter, on a 1987 f150 or do i need a scope?
Unfortunately, you'll most likely need a scope. If you use a multimeter, you will only get a voltage average. The MAP Sensor switches a 5 Volt reference signal supplied by the computer hundereds of times per second, high (5v) and low (0v). The slower it switches (I.E. lower frequency) the more vaccum you have. The faster it switches (I.E. higher frequency) the less vaccum you have. The problem is, your meter can't respond that fast, so it'll read anywhere between 0v and 5v, which is pretty much useless. If you can get a scope on it, you want to set the it to 1v/Div. and 2mS/Div. and look for a clean square wave pattern that smoothly and proportionatly expands when vaccum is applied.
Thanks i got 5 volts with a meter. So ill try again to read my codes, haven't been able to read them yet. if i dont get any code ill check it with a scope.
argo, i have found out that there are two different kinds voltage varrying and frequency varrying map sensors, and your can check the freq with a tach, the test goes as follows : volt cont .... with a good ground on your volt meter, and pos conected to your sig wire ( middle ) with no of vacume it sould be around 5 volt then increase steady up to 5v +-1v, then aply 20hg vacume and your voltage should drop to 1v. a similar test with a frequency varying map use a tachometer and at 20hg you should have about 200rpm
My 95, F-150 was also wanting to die at idle or crusing through a parking lot.
I t would also hiccup sometimes at crusing speed. I replaced the throttle position sensor this past weekend, and now the truck is running fine.
I bought the TPS on EBay for $14.99 + $5.00 s&h. Autozone wanted $31.99.
Clava
1995 Ford F-150 4x4 E4OD ext cab 5.8 188,000 miles
My 1995 F150 (5.0) did about the same thing, and it was the TPS. You can test the TPS with a volt-ohm meter. Cheap part to replace, too - before you start tearing down engines, or replacing harmonic balancers, check that.
This has been a remarkably reliable truck. In 110,000 miles, I have replaced the TPS, an A/C clutch, and an idler pulley. Other than spark plugs, wires, rotor, and cap (and serpentine belt) the engine is as from the factory. Even the original hoses.
TSP seems ok for now. All i had was a meter with 10 volts setting. How did the truck run? Mine is hard to start, if it starts then will idle for 10 mins. then stall each time. I'm having the fuel pressure tested right now. Does auto zone rent out EFI fuel pressure testers?Vip up here doesn't.
Thanks
