FI to Carb conversion
Old May 27, 2004 | 05:19 PM
ruby359's Avatar
ruby359
I have a 79 F150 that has a 89 grand marques engine (302) that was converted from FI to Carb. Its a mess, blowing oil out of the oil stick among other places. Can anyone direct me to information about these conversions, The marques ran like a top the day they pulled the engine (i drove it) So I think it can be salavaged.
Thanks
Old May 27, 2004 | 08:40 PM
LxMan1's Avatar
LxMan1
The only difference should be from the intake manifold up.
The EFI engine had the PCV valve in the center/rear of the intake manifold. Did you install one in the valvecover? Does it have good vacuum to it?
Old May 27, 2004 | 10:01 PM
ruby359's Avatar
ruby359
The pvc valve on the valvecover was attatched to the carb. Its now attached to the intake manifold. Yes it has good vacuum. Would that cause oil to be blowing up from the oil dip tube?
Old May 29, 2004 | 10:44 PM
LxMan1's Avatar
LxMan1
Sounds like a blowby problem. For some reason it is building up too much pressure in the crankcase. This is usually a piston ring problem. What is in the other valvecover? There should be some kind of filter to filter the air being sucked in by the PCV valve,
