My truck pulls to the right. I have had it aligned 2 times by two different shops. Both are about the same readings. Tech say truck should not pull with those readings. Dealer wants OEM tires and rims before the do any more. I have BFG Mud Terrians and Weld wheels. Any thoughts as to what might be causing the truck to pull??
Tires can make any vehicle pull to one side.
Did it pull before the tire switch.If not the tires are a good place to start.
Try moving the front tires to the rear. That may help if it is tire related.
