Big electrical problems with my expo, help!
Old Jun 4, 2004 | 10:33 AM
the4by4freek's Avatar
the4by4freek
I thought it would be lower in amperage also. When I purchased this one that I have this is the information I was given. I was told that the EB has more power options such as LLS and rear heat and air standard equipment. It also has an upgraded audio system which draws more power. They also have factory fog lamps and most have a factory tow pkg. All these options will draw much more power so it made perfect sense to me. I am an electrician and it makes perfect sense. I checked the current draw on my truck and it came out to the #'s stated above. It does draw alot but everything works fine with the alternator I have.
Old Jun 5, 2004 | 08:10 PM
lifeztds's Avatar
lifeztds
Well fellas, I put my truck into ford on tuesday, the 1st and it is saturday the 5th, it's still there and they don't know what is wrong with my expo, FORD doesn't know what is wrong with a FORD, wow! this is terrible.
Old Jun 6, 2004 | 04:17 PM
the4by4freek
You act surprised! There aren't too many competent dealers that actually know what they're doing! If the computer doesn't tell them what is wrong then they are lost. Most dealers don't have mechanics like in the old days..... now they have computer analists that don't know a spark plug from an exhaust system. I just hope they fix it for you and don,t make the problem worse! This is the exact reason I don't use dealerships! I'd rather buy a CD and fix the damn thing myself! Good luck.... it's probably something stupid!
Old Jun 8, 2004 | 04:23 PM
lifeztds's Avatar
lifeztds
Well, she's home, and acting good. The ford technitions didn't see a problem with the truck, alternator or anything but a few blown fuses. Thank you
Ismael Rivas
Modular V10 (6.8l)
Jan 3, 2017 04:43 PM
Inthswamp
Dec 24, 2016 01:55 PM
Trav1990
Nov 6, 2016 09:29 PM
twodogz
2004 - 2008 F150
Jul 26, 2016 01:04 PM
deputydog03
81
Mar 8, 2016 09:20 PM
