what is it?
Old Jun 18, 2001 | 09:24 PM
96f150's Avatar
96f150
what is it?
Ok I have a 95 Powerstroke that I just got today. After looking under the hood, There is a 5 wire flat connector that is atatched to some sort of 5 terminal device that is connected to the passenger side valve cover. One of these wires is not in the connector, and it is taped off by itself. What does this connector do?
Thanks,
Rich
Old Jun 19, 2001 | 03:57 AM
The Diesel Dude's Avatar
The Diesel Dude
what is it?
There should be 2 of these 5 wire flat connectors on each valve cover gasket. The wires are as follows: The center wire on each connector is a common for the injectors, the 2 wires on either side of the center wire are the feed for the injectors, for example the right front connector would feed the 1 and 3 injectors. And the outside wires are glow plug wires. The front glow plug wire on the R/B front connector would go to the #1 cylinder glow plug and the rear wire on the front connector would go to the #3 glow plug.
Old Jun 19, 2001 | 05:08 PM
96f150's Avatar
96f150
what is it?
thanks for the info Joe. It is the connector on the passenger side (rear of the valve cover) and it is the rear most wire, that is pulled out of the connector and taped of with electrical tape. My guess would be if this wasn't connected properly, the engine would have developed some kinda stumble of some sort, but it seems to be fine.
Thank you for your time,
Rich
Old Jun 20, 2001 | 03:53 AM
The Diesel Dude
what is it?
That wire feeds the #7 glow plug. It should start OK on 7 glow plugs.
Old Jun 20, 2001 | 06:07 AM
96f150's Avatar
96f150
what is it?
#7 glow plug, or injector? Or is that the same thing your talking about.
Old Jun 21, 2001 | 08:55 PM
wytfut's Avatar
wytfut
what is it?
most of our psd's don't even use the glow plugs to start... and if i remember right.... international binder doesn't even put glow plugs on their version of this same engine
Old Jun 22, 2001 | 04:41 AM
The Diesel Dude
what is it?
96f150: There should be 5 wires on each connector as follows: the center wire is the common for the injectors. The wire on each side of the center wire is the feed wire for the injectors and the 2 outside wires are glow plug wires. The rear most wire on the rear connector of the right side of the engine is the #7 glow plug wire.
Old Jun 22, 2001 | 04:49 AM
The Diesel Dude
what is it?
wytfut: I don't know if you use the glow plugs to start your Power Strokes or not but rest assured they are there if you need them. And all T444E International engines have them as well and always have.
Old Jun 24, 2001 | 08:51 PM
cpdjr's Avatar
cpdjr
what is it?
[font size="1" color="#FF0000"]LAST EDITED ON 24-Jun-01 AT 09:52 PM (EST)[/font][p]Those connectors are bad about burning out and taking the rocker cover gasket with it Ford and IHC both offer the parts to repair the connector which will keep you from replacing the wiring harness the connector is available in kit form from Ford and contains everything but the pins but it does include the tool to push the pins out of the connector and has enough parts to replace 2 connectors p/n F7TZ-14489-BA it is refered to as a
"sleeve" It is available from IHC as individual parts but they also offer the pins I'm sorry but I can't find the p/n for them
Old Jun 24, 2001 | 09:43 PM
fordiesel69's Avatar
fordiesel69
what is it?
