Engine not run in 2 years
Old May 27, 2004 | 07:29 AM
Jerry ranger9's Avatar
Jerry ranger9
Exclamation Engine not run in 2 years
2.9 lit, needed parts and time, has not run in 2 years, wondering, is there any thing besides changing all the fluids I can do to prepair the engine to run, to prevent damage to the engine, before I start the engine again?
I though there might be a spray to go into the intake to lessen friction in the cylinders?
Thanks
Old May 27, 2004 | 07:38 AM
rangersvt04's Avatar
rangersvt04
make shure there is good gas in the tank and fuel line. clean the manifiold, drain fluids replace.
Old May 27, 2004 | 09:25 AM
StockRanger's Avatar
StockRanger
Make sure battery has a good charge, too..
Old May 27, 2004 | 10:52 AM
Thumper47's Avatar
Thumper47
There may be others who will disagree with me, and I may be wrong, but if it were me, I would pull the plugs and fog the cylinders with somthing like WD40 first.
Advice given by others up to this point seems valid and good.
Thumer47
Old May 27, 2004 | 02:32 PM
Mike W's Avatar
Mike W
I have started engines that have sat for years. Disable the spark first to build up oil pressure.
Old May 27, 2004 | 02:39 PM
Ken00's Avatar
Ken00
I would put a teaspoon of oil in each cylinder and crank it over for a few 10 second shots with the ignition disabled.
Old May 27, 2004 | 02:46 PM
dono's Avatar
dono
Gone but not forgotten.
Ken and Mike have good suggestions. I have also found that a shot of starter fluid can help bring it back to life after a long sleep.
Dono
Old May 27, 2004 | 03:04 PM
TwoDollarBill's Avatar
TwoDollarBill
I've always heard a teaspoon of Marvel Mystery oil in each cylinder. I don't know if that helps anymore than regular oil, but it worked for me. '75 Monte Carlo had been silent for 6 years.
Old May 27, 2004 | 06:54 PM
thesaintoc's Avatar
thesaintoc
A teaspoon of oil in the cylinders is good, a tablespoon will cause fluid lock up and blow a head gasket if you are lucky, bend a rod if you are not.
I have an old 12 volt fuel pump to remove fuel from the tank, while you are at it see if the fuel is really rusty or has water in it. In order to remove the fuel filter you will need a plumbers pipe strap tool or one of those overpriced strap tools from land of the giant job sucking sound.
