Electronic or Manual Guages??
Old May 26, 2004 | 02:36 PM
spyderchamp's Avatar
spyderchamp
I am restoring the interior of my '79 and thinking about doing the aluminium dash conversion. However, I don't know the pros and cons between electronic and manual guages. In some cases they are comparable in price, sometimes not. If it is worth it, it may be a good investment, perhaps some guages should be electric, some should be manual...I don't know. Someone who has done this or knows the dilemma give me a hand.
Thanx,
James
Old May 26, 2004 | 04:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Use an electric oil pressure gage. Hot oil in the interior, or all over you, or the engine is not a good thing.
Old May 26, 2004 | 05:03 PM
Bob Ayers's Avatar
Bob Ayers
I agree, oil pressure is the only gauge that is mechanical, or electrical.
Old May 26, 2004 | 07:14 PM
ivanribic's Avatar
ivanribic
My .02 worth: I prefer mechanical guages any time you can use them. They're dead on accurate and reaction time is instant. I understand Torque's point though. My buddy has a mechanical oil pressure guage in his Chevelle. On his wedding night he hopped in it and caught the pressure line. Oil went EVERYWHERE . . . it was a mess. That being said I'm running one right now and I've found that with the proper fittings they're not a problem. I can't pull the line out of my guage or engine (maybe because I'm a weakling ) and all my lines stay up under the dash where they won't catch on anything.
I will say that my water temp guage was a little tricky to route since the sensor and line could not be detached from the guage but once I got it all figured out it was nice. The only electric guage I've got right now is a tranny temp and I'm looking to replace that with a mechanical soon.
The other plus to mechanicals (in my opinion) is they are typically sweep almost all the way around whereas most electric guages have a short sweep. It's easier to read and seems to be more accurate with mechanicals.
Old May 26, 2004 | 11:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have seen a couple instances where those 1/8" lines broke while the truck was running down the road. The plastic line gets brittle. One sprayed hot oil all over the driver. The other one dumped the oil in the engine compartment and the engine blew. A lot of oil can come out of those lines quick.
The accuracy of the common automotive gage whether mechanical or electrical is not the best tho. They aren't exactly set to the national lab standards... I suppose you could say they were +/- 10% type units if you are lucky and pay some $$$. The cheapo sets are questionable at best.
Old May 26, 2004 | 11:17 PM
spyderchamp
Is the fuel guage elec. or mechanical? I am still using my sending unit for my oil idiot light. Is there any nastiness involved with installation of electrical? Do you have to buy sending units seperately for everything, I have mechchanical oil and water ones right know, and the sending units were included in the box. Sometimes the logistics of these things send me spinning, but in reality, once thought out, not that hard.
Thanx for your help,
James
Old May 27, 2004 | 12:05 AM
ivanribic's Avatar
ivanribic
Fuel level guages are always electrical, using a sending unit in the tank. There's no nastiness to installing electric guages. Most will come with sending units. I highly recommend Autometer guages (always come with sending units). They seem to be very reliable and accurate, not the cheapest but you get what you pay for.
Old May 27, 2004 | 12:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
Now some of them old tractors and implements had mechanical fuel gages -hehe! They had a twisted metal rod that was rotated by fitting thru a slot in a non-rotating float. I am sure there were other designs also. Just some extra info for you.
I haven't seen anything but electrical fuel gages on a car or truck tho.
Old May 27, 2004 | 12:51 AM
ivanribic's Avatar
ivanribic
Okay Torque, I didn't even think about that but I know the exact guage type you're talking about. We have one on our old forklift and one of our lawn tractors use them. Can't get much more mechanical than that. I should have known you'd have an exception to the rule.
Old May 27, 2004 | 01:11 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hey I like to have some fun sometimes I keep pretty busy just reading hundreds of posts everyday and taking care of user problems.
Some of those mechanical gages were built into the screw cap on the tank. Those are easily damaged tho.
Old May 27, 2004 | 08:56 AM
73Custom's Avatar
73Custom
Originally Posted by spyderchamp
Is there any nastiness involved with installation of electrical? ... Sometimes the logistics of these things send me spinning, but in reality, once thought out, not that hard.
I agree with Torque, electric is the way to go. I've had several mechanical guages start leaking and ruin clothes and carpet. But electric guages do require sending units, some guages come with them and some don't, so consider that when comparing prices...
Wiring electric guages is easy, just 4 wires per guage: power, ground, dash lights and wire to sending unit. Very easy, just take it one guage at a time.
Marty
Old May 27, 2004 | 12:32 PM
CrazyAirman's Avatar
CrazyAirman
Best way to eliminate a possible oil leak is to use brass line instead
of plastic. Even if you do use the plastic line, just use common sense in routing it
Old May 27, 2004 | 12:55 PM
ivanribic's Avatar
ivanribic
You mean I was supposed to use a grommet?!?
Where would a person buy a brass line that small? I'd be interested in doing this once I put my new dash in but I've never seen that small a brass tube, not that I've looked.
Old May 27, 2004 | 03:53 PM
CrazyAirman
You can get the brass line at any decent parts store, I havent seen it in kit form, so you will have to get some more of those ferel do-dad thingies.
Its 1/8th if my memory serves me
Old May 27, 2004 | 04:34 PM
KJKozak2's Avatar
KJKozak2
I like the mechanical oil pressure guage. I do understand the concerns though. You guys have me all concerned now. I'm gonna have to look at how I routed it again.
Is it OK to wrap the extra slack around the exhaust manifold? What about the accelerator linkage?
Kevin K.
