What should my timing be?
Old May 26, 2004 | 06:05 AM
joners's Avatar
joners
What should my timing be for my 351W? What do you guys need to know about it? It has Duraspark II ignition, anything else?
Old May 26, 2004 | 06:55 AM
jwtaylor's Avatar
jwtaylor
6 BTDC is the stock recommended setting for your initial, but you can play around with it if you want, taking it up to 10 BTDC will give you a snappier off idle throttle response. Good luck
Old May 26, 2004 | 06:25 PM
joners's Avatar
joners
ok sounds good. I just need to know so I can get it fired up first, then take her to the dyno!
Old May 29, 2004 | 09:29 AM
P51D Mustang's Avatar
P51D Mustang
Factory setting of less than 10* initial are for emissions regulations. I like 12*.
