Drive shaft Pully
Old Jul 15, 2001 | 05:52 PM
NoWake's Avatar
NoWake
Drive shaft Pully
'01 Powerstroke driveshaft pully is wobbling making the belt walk. It had less than 500miles when it started. It is making two different sounds when it is cold it sounds like two pieces of plastic rubbing. Then after driving with the engine warmed-up it is more like two metal ***** ratcheting. I am always worried about sounds, you can hear it at one point get to the dealer and no sound at all. Lucky for me it was still there and the service tech did not look at me like I was crazzzzy. Which I am when it comes to my big white toy.
The truck will go in on Thursday, and I will be hoping the noise stops. If not at least I will have a newer driveshaft pully, one with zero miles on it.
Rick
Old Jul 16, 2001 | 07:23 PM
bigfordman70's Avatar
bigfordman70
Drive shaft Pully
What's a driveshaft pulley? ;-) Is it anything like a crank pulley.
BFM
Old Jul 19, 2001 | 03:13 PM
NoWake's Avatar
NoWake
Drive shaft Pully
Actually I rigged a rope from my front drive shaft while running full time 4wheel drive to power all my other accessories. It saves on fuel coast.
I am just a dumb #####.
They replace the crank pully today....it still wabbles but the sound is gone. They also replaced the belt, we will just have to see.
Old Jul 19, 2001 | 08:16 PM
bigfordman70
Drive shaft Pully
LMAO :7 It happens to the best of us.
I see alot of wobbling crank pullies that run forever, hopefully yours is fixed.
BFM
Old Jul 20, 2001 | 01:54 PM
NoWake's Avatar
NoWake
Drive shaft Pully
What causes the crank pully to wobble? They were surprised to find it still wobbling after putting on the new one. They also put a new belt on. Like I said the noise stoped but I am worried that after 500m or so the sound will come back.
Rick
Old Jul 20, 2001 | 11:07 PM
bigfordman70
Drive shaft Pully
I dunno, but there dosen't seem to be any engine that is immune to it. The pulley on my crown vic has been doing it for 95,000 miles.
BFM
Old Jul 20, 2001 | 11:45 PM
The Diesel Dude's Avatar
The Diesel Dude
Drive shaft Pully
I am assuming you are talking about the vibration damper (the lower pulley attached to the crankshaft). They are made in 2 pieces with a piece of rubber vulcanized in between the 2 (for the purpose of absorbing the torsional vibrations in the crankshaft). It is common for a small amount of wobble to exist. send me the serial number of your engine and I'll check our database to make sure the engine wasn't dropped or otherwise damaged at the factory. (-removed-)
Old Jul 21, 2001 | 02:05 PM
NoWake's Avatar
NoWake
Drive shaft Pully
Joe, I e-mailed you what I think is the engine serial number and manufacture date. How would they know if was droped or damaged.
When you look at the center of the crank shaft pully it appears to be running true. That is why the dearship was surprised it was still wobbling.
Thank you for any information.
Rick
Old Jul 23, 2001 | 12:20 AM
NoWake's Avatar
NoWake
Drive shaft Pully
I was driving home tonight and the noise is comimg back. Like I said the dealer replaced the pulley and belt. The pulley still wobbled but the noise stoped. After looking a bit closer I noticed they used belt dressing. I never needed to use dressing on a serpentine belt. I was given some great information from another member, he stated that there was no sign of damage to the engine.
So, what do I do now I got this noise on a 1000mile engine. And the 99 PSD that I traded in was in great shape...no noises :-(
Not a happy trucker right now
Rick
Old Jul 23, 2001 | 06:16 PM
bigfordman70
Drive shaft Pully
Make 'em fix it again. That's what that warrenty is for.
Hmmmmm, I wonder if Fluidamper or TCI makes a damper for a PSD.
BFM
Recycle...crush a chevy
Old Jul 27, 2001 | 04:51 PM
NoWake's Avatar
NoWake
Drive shaft Pully
I took the truck back to the dealer. They agreed the crank pulley is still not good. They also noticed the idle pulley had some belt burn on it. They are going to replace that also.
Until next week....Lets hope this works
Drive shaft Rick
Old Jul 28, 2001 | 04:29 AM
The Diesel Dude
Drive shaft Pully
We keep an E-file on every engine we make according to serial number. If an engine gets dropped, for example, it has to be sent from where ever it is, to Major Repair. In order for that to be accomplished, a defect (engine dropped) has to be entered into the computer. Then when a repair is made, the repair also has to be entered and this information stays in the computer. But the only defect showing on your engine was a loose fuel line which was caught and repaired on the assembly line before it made a mess on the engine. It was then sent to test where it passed the first time and was sent straight to shipping. (An engine rarely gets dropped, but it has happened.)
Old Jul 28, 2001 | 11:48 PM
jicysa's Avatar
jicysa
Drive shaft Pully
dwild
1997 - 2003 F150
Jul 13, 2011 06:46 PM
jgray
May 16, 2005 05:48 PM
kluxman45
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 4, 2003 10:22 PM
