transmission
Old May 25, 2004 | 12:08 PM
jrjeff's Avatar
jrjeff
transmission
I just purchased a 1999 ford explorer xlt. Not driven this make before I cant tell if it not wanting to downshift or if that is the character of how this truck shifts. at 50 to 60 mph, stomp the pedal and it goes from overdrive to drive and the torque converter unlocks, but the tack never gets any higher than 3200 rpm. But from a standing start the tack will cycle up to 5000 on every shift of each gear. This is no slippage, it will still excellerate rapidly even with it not winding at tight as I think it should for a full throttle downshift(automatic trans by the way). Even from 25 a full throttle stomp will not drop it back to first and some times not even to second gear. I used to have and old SHO that did this and it was a speed sensor but it would downshift at all, this will from o/d go to drive. Any suggestions or is this just the nature of this vehicle.
